JR
Voicie le matchs quond atendais avec plaisir ....et oui JL ses AJ et Angle....JL
Moi je lentendais de pluie 4 jours avec se beau PPV......Mais la se sle theme Song de AJ...AJ et Angle theme song:
ET
VS
Chritians Cage et Edge:
[img]http://farm1.static.flickr.com/143/317408039_845362c716.jpg/img]
et
et le matchs commence:
Aj et Angle vs. Edge & Christian (EWTC Tag Team Championship)
Howard Finkle - This match is a Standard Match tag match for the EWTC Tag Team Championship titles. On there way to the ring at this time, Aj et Angle!!!
[Aj et Angle come to the ring. ]
Howard Finkle - and their opponents, the team of Edge & Christian.
[Edge & Christian walk to the ring. Earl Hebner is the referee for this match. Kurt Angle executes a pumphandle suplex on Christian. Earl Hebner checks Christian's boots and knee pads. (the bell rings) Kurt Angle grabs Christian's head and hites him in the face. ]
Michael Cole - Christian takes a face bite.
[Christian brings in Edge for Edge & Christian. Flying somersault drop kick by Edge puts him back in the match. ]
Jim Ross - Edge executes a flying somersault dropkick.
[Kurt Angle moves back to his feet. Kurt Angle punches Edge in the gut. Edge hits a jumping elbow hrust on Kurt Angle. ]
Michael Cole - jumping elbow thrust!
[Edge tags in Christian. Kurt Angle clotheslines Christian. Kurt Angle mule kicks Christian. Christian brings in Edge for Edge & Christian. Edge goes off the top turnbuckle and double foot stomps Kurt Angle. Edge stands up. Kurt Angle tags in AJ Styles. AJ Styles is back on his feet. AJ Styles hits a jumping elbow hrust on Edge. Edge hits AJ Styles with an earringer. AJ Styles brings in Kurt Angle for Aj et Angle. Edge hits Kurt Angle with an elbowdrop from the second turnbuckle. Edge is up again. Kurt Angle stands up. Kurt Angle trys for a headscissors takeover but Edge avoids it. Kurt Angle and Edge go to the floor Earl Hebner starts the count (.1) Kurt Angle swings a Steel chair and hits Edge. Edge is bleeding as a result. (..2) Kurt Angle pokes Edge in the eye with his thumb. (...3) Kurt Angle gets caught with an elbowsmash to the face. (....4) Kurt Angle with a headbutt on Edge. (.....5) They head back into the ring. Edge attempts to kick Kurt Angle, but Kurt Angle catches his leg. Edge flips around and kicks Kurt Angle. Edge stands up. Kurt Angle is driven further into the mat by Edge with a diving elbow smash. Edge moves back to his feet. Edge covers Kurt Angle hooking the leg. Referee Earl Hebner makes the count. ...1 ...2 Kurt Angle escapes. ]
Howard Finkle - You just can't win this early in a match. Especially with an opponent like Kurt Angle.
[Kurt Angle is back on his feet. Edge brings in Christian for Edge & Christian. Edge executes a ropeflip hiptoss on Kurt Angle. ]
Jerry "The King" Lawler - The double team is the key to Tag team wrestling!
[Kurt Angle short lariats Edge. Edge tagged in by Christian. Edge moves back to his feet. Kurt Angle holds his mouth after recieving an elbow smash to the face. Christian tagged in by Edge. Christian moves back to his feet. Kurt Angle gets caught with an elbowsmash to the face. Kurt Angle brings in AJ Styles for Aj et Angle. Christian elbows AJ Styles in the stomach, trying to even the match. Christian brings in Edge for Edge & Christian. AJ Styles grabs onto Edge and a Belly to Belly Suplex sends Edge down onto the chair!! Edge is up again. AJ Styles gets thrown into the turnbuckle. Edge comes at him and drills him with the splash. Edge drags AJ Styles to the floor. ]
Howard Finkle - Edge can get a weapn at ringside.
[Earl Hebner starts the count (.1) Edge swings a Steel chair and hits AJ Styles. AJ Styles is bleeding as a result. Edge hits the flying legdrop across AJ Styles's neck. Edge chants start. Now Edge standing. (..2) ]
Jim Ross - Edge's momma would be proud!
[(...3) Edge jumps and elbow smashes the lying AJ Styles. Now Edge standing. AJ Styles moves back to his feet. (....4) AJ Styles executes a swinging bulldog on Edge driving Edge's face into the floor. Now Edge standing. (.....5) Edge and AJ Styles move back into the ring. A flying shoulder block send AJ Styles to the mat. Now Edge standing. AJ Styles gets up. AJ Styles lifts up Edge and delivers a Gut Wrench Powerbomb on the open chair! AJ Styles chants start. Edge gets back to his feet. Kneelock submission applied by AJ Styles. The referee is checking the situation. ... (AHHHH!) ... (AHHHH!) ... (AHHHH!) AJ Styles breaks the hold. AJ Styles positions Edge. He hooks both of his arms...Double Underhook Suplex on the chair! ]
Howard Finkle - Good Double Underhook Suplex by AJ Styles.
[AJ Styles is back on his feet. Edge gets back into the match with a jumping neck snap on AJ Styles. AJ Styles punches Edge in the gut. Flying somersault drop kick by Edge puts him back in the match. ]
Michael Cole - Edge with a flying somersault dropkick.
[Edge tags in Christian. Edge hits AJ Styles with a flying senton. AJ Styles is driven further into the mat by Christian with a diving elbow smash. Edge hits AJ Styles with an elbowdrop. ]
Howard Finkle - This is just awefull! AJ Styles is being double teamed!
[Edge flies from the turnbuckle with an elbowdrop. ]
Michael Cole - Edge with a elbow drop.
[Edge is back on his feet. Edge goes for a pin. Earl Hebner counts the pin. ...1 ...2 AJ Styles escapes. ]
Jim Ross - Not even close!
[AJ Styles gets up. AJ Styles brings in Kurt Angle for Aj et Angle. Flying somersault drop kick by Christian puts him back in the match. Christian gets up. Edge tagged in by Christian. Kurt Angle punches Edge repeatedly. Kurt Angle brings in AJ Styles for Aj et Angle. AJ Styles dropkicks Edge. Edge climbs to his feet. A tilt-a-whirl powerslam by Edge shows his true strength as he slams AJ Styles into the mat. Edge chants start. ]
Michael Cole - If Edge keeps using moves like that tilt-a-whirl powerslam he could win the match!
[AJ Styles moves back to his feet. Kurt Angle tagged in by AJ Styles. Kurt Angle catches Edge's leg, but Edge reverses it with an enzuigiri to Kurt Angle's head. Edge gets up. Kurt Angle delivers a spinning backbreak to Edge. Edge tags in Christian. Christian gets hit with a dragon scerw from Kurt Angle. ]
Jerry "The King" Lawler - Christian takes a dragon screw.
[Kurt Angle is up again. Christian brings in Edge for Edge & Christian. Edge executes a ropeflip hiptoss on Kurt Angle. Edge brings in Christian for Edge & Christian. Kurt Angle, trying to get some advantage, puts Christian in an achilles tendon hold. Kurt Angle climbs to his feet. Christian tags in Edge. Kurt Angle gets caught with an elbowsmash to the face. Kurt Angle hits a kneeling headbutt to Edge's groin. Edge gets up. Kurt Angle brings in AJ Styles for Aj et Angle. Edge on the turnbuckleAJ Styles rising from the mat,Edge leaps from the top rope with a bodypress. Edge stands up. Now AJ Styles standing. AJ Styles,standing on the top rope posing for the fans,is caught by suprise. Edge German suplexes him Edge chants start. ]
Jim Ross - AJ Styles could use some help about now.
[AJ Styles tags in Kurt Angle. Kurt Angle gets elbowed to his midsection by Kurt Angle. Edge slaps both sides of Kurt Angle's head out of desperation. ]
Michael Cole - Edge executes a earringer.
[Edge hits a flying karate chop right to Kurt Angle's neck. ]
Howard Finkle - flying karate chop!
[Kurt Angle gets caught with an elbowsmash to the face. Kurt Angle hits a spinning leg lariat on Edge sending him to the mat. Edge is back on his feet. Kurt Angle tags in AJ Styles. AJ Styles gets back to his feet. AJ Styles executes a spinning DDT, planting Edge's head in the mat. AJ Styles gets back to his feet. AJ Styles sets the chair down on Edge...AJ Styles goes up top..Splash onto the chair! Edge is hurting! The ref starts the count. ...1 ...2 Edge escapes. ]
Michael Cole - That was almost the end of the match right there!
[Edge gets back to his feet. AJ Styles drags Edge to the floor. Earl Hebner starts the count (.1) AJ Styles swings a Steel chair and hits Edge. Edge is bleeding as a result. ]
Howard Finkle - I wish every match could be like this!
Jim Ross - The floor is covered with blood from that injury.
[AJ Styles with a huge fisherman buster on Edge. AJ Styles chants start. (..2) ]
Howard Finkle - The floor is covered with blood from that injury.
[(...3) AJ Styles drives a forearm into Edge. (....4) Edge hits a jumping elbow hrust on AJ Styles. AJ Styles is back on his feet. (.....5) AJ Styles and Edge move back into the ring. AJ Styles uses a snap mare takeover on Edge. AJ Styles tags in Kurt Angle. Edge punches Kurt Angle repeatedly. Kurt Angle makes the tag to AJ Styles. AJ Styles executes a neck-breaker on Edge. AJ Styles bounces Edge off the ropes and clotheslines him. Kurt Angle delivers a kick to the head of Edge. ]
Jerry "The King" Lawler - That's it cheat!! It's the only way to win!
[Flying lariat by Edge takes Kurt Angle down. Edge chants start. Edge moves back to his feet. Christian punches Kurt Angle repeatedly. Kurt Angle can't breathe after a sitdown splash by Edge hits him in the chest. Edge climbs to his feet. Edge sends Kurt Angle to ringside. Earl Hebner starts the count (.1) Kurt Angle stands up. (..2) Kurt Angle slaps Edge. ]
Michael Cole - Kurt Angle executes a slap.
[(...3) Edge goes off the top turnbuckle and double foot stomps Kurt Angle. (....4) Edge hits Kurt Angle with an elbowdrop. ]
Jerry "The King" Lawler - Follows up with a elbow drop.
[Edge is up again. Kurt Angle climbs to his feet. (.....5) Edge takes Kurt Angle into the ring. Edge whips Kurt Angle's feet from under him with a side kick. Edge moves back to his feet. Edge tags in Christian. Christian sets AJ Styles up DDTs him into the mat. Christian piledrives AJ Styles. Christian sets AJ Styles up DDTs him into the mat. ]
Howard Finkle - AJ Styles is being double teamed!
[AJ Styles applies an arm wrench to Christian. Christian climbs to the top turnbuckle and executes a somersault legdrop on AJ Styles. Christian is back on his feet. An elbow submission by Christian brings AJ Styles down to the mat. The referee is checking the situation. ... AJ Styles trys to escape. ... AJ Styles trys to escape. Christian breaks the hold. Out of desperation, Edge dives from the second turnbuckle, shoulder blocking AJ Styles. AJ Styles makes the tag to Kurt Angle. Christian hits Kurt Angle with an elbowdrop from the second turnbuckle. Christian stands up. Kurt Angle stands up. Christian gets picked up and dropped with the fireman's carry by Kurt Angle. ]
Jim Ross - Christian takes a fireman's carry.
[Christian makes the tag to Edge. Kurt Angle hiptosses Edge. Edge is back on his feet. Edge hits a flying karate chop right to Kurt Angle's neck. Kurt Angle tags in AJ Styles. Kurt Angle executes a split legged moonsault on to Edge. AJ Styles picks up Edge and drops him neck first on the ropes. ]
Howard Finkle - Edge is being double teamed!
[Running neckbreaker drop executed by AJ Styles takes Edge down hard. AJ Styles chants start. Edge gets back to his feet. Edge gets caught with an elbowsmash to the face. AJ Styles picks up Edge and delivers a tilt-a-whirl suplex. AJ Styles is back on his feet. AJ Styles hits the flying legdrop across Edge's neck. AJ Styles is back on his feet. AJ Styles goes up to the top, and comes down with a Shooting Star Press right on the chair!! AJ Styles runs up to the top and a Moonsault body press on top of the chair and Edge!! Earl Hebner counts the pin. ...1 ...2 ...3 ]
Howard Finkle - The winners of this match, and new EWTC Tag Team Championship champions, Aj et Angle!!!
EWTC Tag Team Championship championsVictoire-3 Défaites-0
